Close but no cigar!
Ty
08-21-2002 06:24:18
Made a little progress on the B. New gas, plug wires, spark plugs, and ign. switch. Spark stays now and is nice and blue. It still doesn't go. Pull choke 3/4 out putt.....putt..... ..... ..... ..... ..... ..... push it in putt..... ..putt..... ..... ..... ..... ..... .... Plugs a little black and exhaust a darker blueish color. Had valve, flywheel, and crank case covers off for getting time. Been through shop manual a dozen times. Put the fly cover on w/ the center punched out and the dot on the hub lines up w/ the mark on the fly cover as well as the L.H. IMPULSE with the gear cover on the right. Need advice want to get the neighbors B OUTTA HERE!!!! WICO XB Battery Ign. Dist.
Lyle Pfeifer
08-22-2002 15:27:17
 Re: Close but no cigar! in reply to Ty, 08-21-2002 06:24:18
Had a similar problem with my "A". Once I was sure of the spark, I tore the carb off and dipped it in carb cleaner. Had to do it twice as I found an idel jet that was completly plugged. There are several small passages in that carb so make sure they are clean. Also, check your float level as that may account for the black on the plugs too. I learned about this the hard way as the drain broke on the carb bowl and I cheeped out. I just didn't drain it over the winter and the float got a little bent because of the frozen water. Thats how this whole mess started, a $1.00 dollar broken drain. Good luck....Lyle
Dale W
08-21-2002 22:33:07
I agree 100% with Mark. Get rid of xb dist. and replace it with a Wico x magneto. I did this to my 50 B about15 years ago, and it has started good every since. Good luck....
Mark
08-21-2002 14:02:33
Try with new plugs first. If it won't start then, throw that Wico XB as far as you can and install a Delco Remy dist. or a regular Wico X mag. Maybe you should try a mag that is known to be reliable also. That XB dist wasn't very dependable. I had one on a 50, it wouldn't start either. I then put a Wico X mag on it and it starts every time right off. Good Luck.
