1010 Replacement Engine
Hunter n NOLa
12-21-2003 04:06:09
Does anyone know where I can find a rebuilt short block for a 1010 diesel? Deere no longer has one available. Are there any other model engines that will bolt up to the 1010 configuration.
440Sam
12-22-2003 19:57:42
 Re: 1010 Replacement Engine in reply to Hunter n NOLa, 12-21-2003 04:06:09
If you want to go gas an engine from a early 40 combine will bolt up (115ci power unit) same engine was in the early 600 Hi Crops (sprayers) I understand this engine was also in a JD Swather. The engine from a 45 combine will also bolt up but it is a larger engine same as 2010 (145ci). As for as diesel I do not know any other applications. The 2010 and 1010 engine blocks were the same only the internals were different.
Mel
12-22-2003 19:19:41
The sleeve deck from a 1010 Diesel is different than a 2010. I have both decks sitting in my garage. The sleeves are bigger in a 2010 but all of the holes line up and the deck itself is the same size. They are still available fron JD for $475. To interchange them, you would have to bore the block itself where the sleeve o-rings go to make it fit.
Bret
12-22-2003 06:41:39
I'm currently rebuilding my 1010 gas. This wasn't Deeres best engine design, though if I take care of it, it should last me till I drop. Seeing all the engine swaps people do, it would seem reasonable to assume there is an engine somewhere of better deisgn and maybe 15 or so more HP that would fit. I plan on making a tracing of the outline of the block and bellhousing along with measurements so that I have an idea if this engine dies. A nice 3 cyl deisel of about 45 HP would be nice. Any more HP would be too much for my crawler I think. Ideas?
Leroy
12-21-2003 17:47:14
Don't know about the diesel but on gas a 145G engine from a 45 gas combine will bolt in
jdemaris
12-21-2003 06:31:17
I've come across quite a few 1010s and 2010s with rebuilt shortblocks from Central Tractor. I think they were bought out by Tractor Supply Co. I've got a 1010 and 2010, and it looks as though the engines are interchangible - although I've never tried it. I worked on hundreds of the things as a JD mechanic, but never had occasion to compare engines, side by side. One person told me he took a sleeve deck and pistons from a 2010 and put them into his 1010 block. I don't know if it was true. It would be easy enough to check by part numbers, I guess. See if the rod bearings match between 1010s an 2010s, and see if the engine block numbers match. Back to your engine, why don't you rebuild the one you have?
