3130 or 2840 with 145 loader HELP
Harry
12-20-2003 20:46:11
I need to remove the loader on my 3130 same as 2840. I have the stand but not the two lift links. My dealer tells me they are no longer available, but have been sub. to the 146 link. which may or may not work, for $236.00. Even he thought that was over priced! From the parts list, they just look like two pieces of bar stock. If anyone has these links, would you please tell me the size of the stock and the length. and the distance between the hole and the slot. Can't take more than 30 minutes to make them. Many thanks. Merry Christmas>
Mike
12-21-2003 13:33:32
 Re: 3130 or 2840 with 145 loader HELP in reply to Harry, 12-20-2003 20:46:11
If you ever take the loader off using the stands,you will only do it once.The stand was made for a tricycle tractor,trying to use it to get one off a w/f tractor is an adventure.If you don't do everything just right,you risk having the loader slip and dent the hood,or slip off the stand(I did both) Its alot easier to park it in a shed or under a tree,and use a come-along and a chain to lift it slightly off the mounts,and back out of it.I can get mine off in about 5 minutes using a come-along and chain.As far as I know, the 2 pieces of bar stock you are looking for, are safety stands,to keep the loader up while you are working on the tractor.
Harry
12-21-2003 15:11:14
 Re: Re: 3130 or 2840 with 145 loader HELP in reply to Mike, 12-21-2003 13:33:32
Thanks Mike,
The two 2 pieces attach to the tractor frame, (mine has the pins in the holes) the slotted end attachs near the top of the loader. When you back up it pushes the loader up and off the tractor, as well as keeping it straight or from hitting anything. The photo shows it on a wide front end 2840. Sounds like you need a pair too. I would be glad to email you the instructions from the manual, if you like.
Mike
12-21-2003 15:44:17
 Re: Re: Re: 3130 or 2840 with 145 loader HELP in reply to Harry, 12-21-2003 15:11:14
I've got the manual,as well as the stands and the irons. Like I said, try it once and you will end up taking it off in a shed. You need a dead level spot,(not level loader hits the tractor)hard so the stand doesn't sink in(stand sinks in,you'll play h#@ getting it back on). Mine is 5 minutes off with the loader chained to a shed beam and no damage to the tractor.
Harry
12-21-2003 20:49:20
 Re: Re: Re: Re: 3130 or 2840 with 145 loader HELP in reply to Mike, 12-21-2003 15:44:17
I plan to take it off in the shed anyway. Concrete floor. but the roof beams wouldn't hold the loader. No trees around here big enough for that. (TX) Guess I could weld up an A-frame to hold it. Thanks for the tips.
