JD 300 Industrial.
JA
08-20-2002 07:01:15
Please help. I know zero about John Deere's and tractors, so you're talking to an ignorant city boy. I have checked this forum for info on JD300 Industrial but all I can surmise is it's similar to the 1020..which doesn't mean much to me. Can any one answer following. This unit is for sale locally. Cab, front end loader, scrapper box and it has "shuttle shift" whatever that is. Used by local landscaper.
1. It's a 3 cyl gas. What's the horsepower?
2. It was bought new in 1968? and has 1,950 hours.? Is that a lot of use?
3. I know nothing about the hitch system. Are these 3 point hitch?
4. Does this have live PTO? There's a rubber cover where I expect PTO but owner says "never used it".
5. Tires are new front and back, runs very well, all hydraulics work smooth, the shuttle shifts works. (Tractor moves back and forth but there is about 2 second delay, is this normal) Has wheel wheights, but owner says "compensator" doesn't work. I think this is something to help steering when bucket is loaded?? is that right? What will it mean to fix it.
6. Since I'm not real handy I'd have to have local JD service. Are these a "servicable" and decent model or are they a clunker.
7. Asking price is $6,000, sounds like $5,500 will have it delivered.
8. Please, I need all the help I can get as I can't afford to make a mistake. I have a small 15 acre place, need tractor for maintaining 1/2 mile driveway, and brush hog use...snow removal in winter (MN)... will this handle a small snow blower, 6FT??
Thnks for you understanding. Jim
cannonball
08-20-2002 19:50:55
 Re: JD 300 Industrial. in reply to JA, 08-20-2002 07:01:15
a jd 300 was built from 1975 to 1979 (gas) it is 43 hp...the price you are talking about is good price if everything works..yes the shuttle shift is slow when the engine rpm is low but gets faster when rpms are up..you have a screw to adjust this time also..pto- if clutch is adjusted it is a lot like live but is not live..you move clutch about 3 inches for stopping fluid to shuttle clutches.. i think if you look at the picture of the 1020 you will see the front hubs are heavier and probably axle...i have 300b and 401b...the 300b is 1973..and 401b is 1981..i use 401b to run 9 ft khun..both have shuttle...if need any more info just email me..have nice day may god bless
Brandon
08-20-2002 19:41:20
The JD300 is an industrial version of the 1020. The JD300 or 1020 are basically the same thing, but with a different front axle, and some other changes. So Steve's post gives you the info you need.
Good luck,
Brandon
Steve - IN
08-20-2002 12:09:46
third party image
JA,
I've got a 1020, so I'll try some of your questions. First double check that a 300 IS a 1020, I've read that a 300 is a 1010, and a 301 / 301A is a 1020 / 2020. The '68 year makes it a 1020, as 1010's latest date is '65 -- but double check.
1. About 38 gas or Diesel.
2. 1950 hours is light use. 3. Is on a 1020. You should see two bottom draft bars and a center top link. This picture might help. 4. PTO, should be a lever on the left side below the seat to engage the rear PTO, and there should be a steel PTO shaft under that rubber cover. Check this one out carefully, you won't be doing any bush hoggin without a PTO.
5. Shuttle shift sounds ok. Can't find anything in 1020 manual called a compensator. It should have power steering. 6. Good model. Parts still available. At 1950 hours, should be a long, long time before you need any major work.
7. Saw a 1020 w/loader go for 8,000 this spring.
8. Double check on the 3pt and the PTO. You'll need them to bush hog and run a snowblower.
We've never had a blizzard so bad that the 3pt swivel blade on the back of the 1020 couldn't make short work of it on the driveway -- but we're not in Minnesota. Blades are a lot cheaper than snow blowers. We traded 40 bales of hay for our old Dearborn blade years ago. The price was right.
On second though, here's my 1020 with the old blade on the back. The green bars holding up the red blade are the 3pt.
