JD 60 Hub wedges
KB
12-20-2003 18:29:59
Had a wheel come loose on the 60 today. Took the wheel off and found that the wedges are worn (they won't set on the axle without rocking) and the key that is cast into the one wedge is much smaller than the slot in the axle. Anyways does anyone know where I can get one and/or what else I should inspect or can do to make these work until I get the replacements?
Thanks for your help.
Steve
12-21-2003 14:18:49
 Re: JD 60 Hub wedges in reply to KB, 12-20-2003 18:29:59
I have a friend that has a 60 he's robbing parts off of, Let me know if you can't find one I know at lest one of his will be good. Steve at [email protected]
MIKE HANLEY
12-20-2003 20:53:35
Had one crack on us one time on the 630. I think there are all the same even into to the newer smaller JD's. $100 something rings a bell and our dealer had it in stock. Check your axel for wear. There was a 620 with a broken axel in the dealer two summers ago. When I saw the new axel, I asked "Big buck's"? No they said, it was from someother place then JD and was I think $350.
