B backfires through carb.
Dick
10-17-2003 17:49:15
I have a 46 Electric B. Just put new rings on the pistons, new valves, and also a new manifold. Sometimes when starting I get a back fire from the carb. I am pretty sure the mag is set to fire at the correct time. I pulled the carb off and put a sheet of paper over the intake on the manifold and cranked it, and it was always sucking the paper against the manifold and never blowing it away. This does not always occur, but would like to know what it might be. Any info would be appreciated.
R. Marg
10-17-2003 18:47:11
 Re: B backfires through carb. in reply to Dick, 10-17-2003 17:49:15
that could be in the carb sometimes when a piece of dirt or what ever get in there it can cause that type of problem and if only does it once in a while that is what it probably is
Frank
10-19-2003 00:47:54
 Re: Re: B backfires through carb. in reply to R. Marg, 10-17-2003 18:47:11
Sounds to me more of a intake valve sticking open?
Don't know if the overlap of the cam would give you a positive pressure out the intake but it should go to neutral; no suction. What about a compression test at the spark plug holes or just stick your finger in the hole and feel if you get the suction and pressure there!! Yeah, I think that'd be my first look at.
tractordan
10-22-2003 06:10:11
 Re: Re: Re: B backfires through carb. in reply to Frank, 10-19-2003 00:47:54
I agree with Frank
