Clooney, do you use 5718 companion after the 5717?
scott#2
12-20-2003 14:25:06
Seems a little redundant to me. Ia m assuming the 17 is the tougher stuff. Do you know what the 18 even does? You still rinse it with water and after looking at a site that did rust removal tests, the 17 did a better job than the 18. Maby its a chemical reaction thing before paint?
Thank You,
scott#2
Clooney
12-20-2003 14:48:26
 Re: Clooney, do you use 5718 companion after the 5 in reply to scott#2, 12-20-2003 14:25:06
Scott, I think the 5718S is pre-diluted & the 5718S is dilutable at about 2:1....
~I haven't used metal prep in quite a few years as I use a home brew of Phosphoric acid to treat my projects..
~It looks like either 5718S or 5717S will do the trick & both do require a washing after application & working time..
~According to an old tec sheet I have on the metal prep it says to use the 517 first then the 518 but that doesn't seem necessary.. My suggestion would be to call you local paint store where you bought the metal prep or call the DuPont help line..
[email protected]
scott#2
12-20-2003 14:53:46
 Re: Re: Clooney, do you use 5718 companion after t in reply to Clooney , 12-20-2003 14:48:26
Thanks for the help. Im just learning this painting thing and want to try to do it right the 1st time.
scott#2
