JD 950 battery draining
Gene
08-18-2002 19:38:20
JD 950 battery draining when tractor sits for a week, battery has been replaced and still same problem. What should I look for ?
randy
03-09-2004 12:03:29
 Re: JD 950 battery draining in reply to Gene, 08-18-2002 19:38:20
Hopefully I will be a jd950 owner someday, A trick I have used is to disconnect the neg cable from battery, install a dc test light between the neg bat post and the neg bat cable. If there is no light on then nothing is robbing from the battery, BUT if it is on make sure everything is switched off and start the process of elimination until the light goes out. pull fuses one at a time,to isolate circuits. disconnect the hot wire to the altenator etc,A volt meter may work better to see exactly how much , instead of the light a small amount may not light the lamp in the tester.Hope not too much here but it has worked for me many times in different applications.
