Trannsmission noise on 70
Aaron
08-18-2002 13:17:22
Have a 70 that makes a grinding noise while goin down hill in 3rd and 4th gear. The noise is coming form the right side of the tractor under the first reduction gear cover. Has anyone had this problem before? What do i need to fix
it? Thanks Aaron
Tony 630
08-19-2002 16:40:47
 Re: Trannsmission noise on 70 in reply to Aaron, 08-18-2002 13:17:22
Aaron
Don't worry about it, the job is actually a piece of cake. Move your tire out and if possible remove hub from tractor axle-you need the space. While in this area you need to remove the brake - three bolts attach it to the rearend case(the cover will not come off without removing the brake). NOW, the hardest part can be removing the clutch if you don't do it right. Take your clutch apart piece by piece. DON"T FORGET TO DISENGAGE THE CLUTCH and then REMOVE THE CLUTCH FORK FIRST. You will have a mess if you do not pull the clutch. from there you will see a little cover to the left of the belt pulley cover. Remove and loosen nut. You will most likely find your problem with this bearing....You can stop here but you need to go on and check under the cover by removing the bolts that hold it on. Hope I haven't forgotten anything.
Order a new gasket from the local JD dealer and replace other parts needed. Bearings etc.
All the John Deere guys know who MR. THINKER is and taking a quote from one of my favorite columnist - if I do say so myself. GET YOURSELF A PARTS manual, A SERVICE manual, & OWNERS manual if available. And yes, somebody has one somewhere you can borrow. Take care of it as your own don't grease the pages up with finger prints. Even as vague as he I & T manual's are, they can help. Then read them all. I'm not being hard, just truthful. I have one set of books for each of my tractors.
I just did the one on my 630. Piece of cake. Honestly probably more bull work removing the tire than anything else.
Good luck.
Tony 630
Aaron
08-19-2002 17:16:16
 Re: Re: Trannsmission noise on 70 in reply to Tony 630, 08-19-2002 16:40:47
Tony thanks for the reply, Did you have the problem in all gears or just one or two. And the cover your talken about by the pully, do i find that cover after the pully is removed? I dotn have a manual for this tractor yet but have one for my 730 which should get me thorught till i order one. Thanks Aaron
Tony 630
08-20-2002 09:25:09
 Re: Re: Re: Trannsmission noise on 70 in reply to Aaron, 08-19-2002 17:16:16
No I didn't have any noise problem. I just got through putting new gaskets and bearings in my 630. Like I said not a bad job.
Yes the 730 book should be of plenty assistance in pictures and in directing how to disassemble your 70. Parts and numbers need to be out of the 70 book.....
Tony 630
If you need help just e-mail me and put something in the subject letting me know what its about. I don't open e-mail from just anyone....
Aaron
08-19-2002 17:15:04
JDM Guy
08-19-2002 09:13:38
Aaron all that noise is the wieght of your 70 pushing the the tractor forward. When the clutch is engaged and your going down a hill it will make that noise and also speed the engine up alittle. Nothing to be worried about unless it makes the noise all the time. You may want to check the trans oil too. When I heard the same noise your hearing I thought somthing was wrong too. Then the guys on this board helped me out.
Aaron
08-19-2002 15:46:08
 Re: Re: Trannsmission noise on 70 in reply to JDM Guy, 08-19-2002 09:13:38
JDM Guy, I know i have a more serious problem then just gear oil. It dont do it in any other gears and it does make the noise all the time just alot worse goin down hill. It kinda sounds like a bad bearing to me but im just not sure which and how to go about fixing it. Thanks Aaron
DILLON
08-18-2002 23:44:18
BECAUSE YOUR A DUMBASS
Frank M.
08-19-2002 17:08:13
 Re: Re: Trannsmission noise on 70 in reply to DILLON, 08-18-2002 23:44:18
Not only are you rude but you had to post that rudeness 12 TIMES. Get a life.
DILLON
08-20-2002 21:58:27
 Re: Re: Re: Trannsmission noise on 70 in reply to Frank M., 08-19-2002 17:08:13
SUCK MY DI*K B**CH
I don't think you have one
08-21-2002 04:14:49
 Re: Re: Re: Re: Trannsmission noise on 70 in reply to DILLON, 08-20-2002 21:58:27
nt
DILLON
08-18-2002 23:44:14
DILLON
08-18-2002 23:44:11
DILLON
08-18-2002 23:44:06
DILLON
08-18-2002 23:44:02
DILLON
08-18-2002 23:43:58
DILLON
08-18-2002 23:43:55
DILLON
08-18-2002 23:43:51
DILLON
08-18-2002 23:43:48
DILLON
08-18-2002 23:43:41
DILLON
08-18-2002 23:43:32
get a life
08-21-2002 19:14:48
 Re: Re: Trannsmission noise on 70 in reply to DILLON, 08-18-2002 23:43:32
everthing you posted pertains to you and you only
DILLON
08-18-2002 23:43:21
