John Deere 140
Geoff Botman
08-17-2002 22:11:11
I have a 140 the hydro wont go into gear! do i need new gear oil if so what brand and type sould i use!
actual geoff botman
08-18-2002 21:35:02
 Re: John Deere 140 in reply to Geoff Botman, 08-17-2002 22:11:11
i did not post this
an angry friend posted it
i know everything about 140's
RayP(MI)
08-18-2002 19:15:58
Dextron works well in that use. If you're low enough to need that much added, you probably should drain the transmission and refill with fresh. This can be done by removing the elbow at the front- bottom of the transmission. While you're at it, replace the filter in the top front of the transmission, available at Deere, NAPA, and other auto stores.
