JD 5020 hydraulic 0il leak
stan
08-17-2002 19:38:40
I have a JD 5020 that is leaking hyd oil out the clutch inspection plate. Am I facing a split job, or could the oil be from another source. Any suggestions will be appreciated. Thanks Stan
Brokenwrench
08-18-2002 14:47:12
 Re: JD 5020 hydraulic 0il leak in reply to stan, 08-17-2002 19:38:40
Sorry to be the bearer of sad tidings, but you will have to split the tractor. You have either bad seals on the trans. input shaft, or if its a console the sealing rings on the pto engagement piston rods are leaking. I would replace the input shaft seals in either case, and check the clutches while its apart as a preventative measure.
eb77
08-20-2002 19:22:57
 Re: Re: JD 5020 hydraulic 0il leak in reply to Brokenwrench, 08-18-2002 14:47:12
I have the same problem with a 1969 4020 console. Does the same apply?
Steve J
08-18-2002 20:57:11
It could be the rear main seal also. For info, they never made a console 5020.
