John Deere M overheating
Truman
08-17-2002 18:22:59
Can someone tell me how to stop my M from overheating ? I have recently rebuilt the engine and had the radiator re done. Installed new belts. Installed a new temperature gauge and it goes into the red just minutes after start up Can anybody help ?
Bus Driver
08-18-2002 11:08:46
 Re: John Deere M overheating in reply to Truman, 08-17-2002 18:22:59
With thermo-siphon cooling, it is necessary that the radiator be full ALMOST to overflowing when the engine is hot. Coolant too low results in no circulation at all on this tractor. With a pump, any coolant in contact with the pump gets moved around, but the continuous coolant loop is necessary for the thermo-siphon system.
JDM Guy
08-18-2002 04:55:46
Heres some things that could make your M over heat. #1 to much anti freeze not enough water. #2 Guage could be no good. #3 Radiator cap not tight and also John Deere chose a poor spot to put the guage sensor, right by the manifold. Just try to run enough anti freeze to keep the engine from freezing and test your guage in a pot of boiling water.
Jeff's 40
08-17-2002 21:54:17
Truman,
I can't remember anytime my 40 ever over heated. Did it overheat, or did the gauge go into the red??? Just because a gauge is new doesn't mean it is good. You can check it against a candy thermometer in a pan of boiling water. If the gauge checks O.K. run the tractor with just water in the radiator. If that works than mix in just enough anti-freeze to keep it from freezing this winter and see if it get too hot.
Hope you find the problem
Jeff
kerry
08-17-2002 20:11:49
Isn't that one of the tractors without a water pump? If you poured the antifreeze into it without pre-mixing it with the water, you may have cut down the flow. The "right" way is to mix the water and antifreeze, then pour it in. The antifreeze is too thick to flow right.
Just a thought, my grandfather had an MT and told me about it.
Kerry
