Best place to get 730 Injection pumps redone
Paul
12-20-2003 08:45:17
I would like to ask you guys your experiences with who does the best work on rebuilding injections pumps and nozzles for the 2 cylinder diesels? We'll be putting a 730 DEL in the shop this winter and it will get a complete overhaul - new pistons, new valves and guides, crank work if needed, etc. I want it to run like a brand new one when done. There are several advertisers in Green Magazine for this work - Roger Marlin in Missouri, Red Oak Diesel Clinic in Iowa, Renaissance Tractor in Washington state, Roy Ritter in Savannah Missouri, Central Fuel Injection in Iowa - I'm sure there is more. Thanks for your comments about your experience.
Mud Masher
12-20-2003 18:11:23
 Re: Best place to get 730 Injection pumps redone in reply to Paul, 12-20-2003 08:45:17
My 2 cents, Roy Ritter did my '49 "R" system and my 830 ES Rice Special's.Excellent top notch work.I've delt w/ Albert also and he too is fine person. Roy, the best I can remember, was a JD shop foreman for 30+ years and when he retired,the calibrating bench and other instruments went with him,setting one up(pump&Injectors) is just like skipping rope.Beware that Roy can talk a wolf up to a campfire,so schedule plenty of time when talking to him.
MIKE HANLEY
12-20-2003 13:36:36
Over hauling a 730D to like "NEW". Be sitting down when write the check for parts. Don't know if you have been following the saga of the missing horses or not. But to recap: Had are main 730 D overhauled 1200 hours ago at a John Deere dealer. Long story short The dealer never checked the cylinders for out of round and put the old pistions back in The diesel shop that they sent the pumps and injectors out to did a poor job. The head was never resitted, the valves were ground and put back in. We did put on a loc-tite fylwheel and the bill was a cup af coffee short of $5,000. It ran good but didn't have the power of the back up 730D we paid $2,300 for. That JD dealer is no longer in bussness and the mechanic has since died. That tractor was his last overhaul and he came out of retirement as the dealer didn't have anyone on staff that ever overhauled a 730D before. The tractor is now at a DIFFERANT JD dealer that HAS a GOOD two cylinder mecanic on staff. and we tore it apart again. This dealer has it's own in-house diesel shop for pump and injector work. It's 5 dealerships under one ownership with the diesel shop at one of the shops. The primery pump was worn out at the piston in the relive valve, giving poor pressure. That was all machined out and bushed back to factory specs.They said that it was pretty clear the the rack and the injectors were just cleaned and put back togther without any new parts. When we got into the engine proper, the old cylinders were already .090 over and they will not go over .090 on a Waterloo tractor even though there are aftermaket pistons to .125 over. We bored the block ad sleved it back to factory. The head got new seats and new valves and was machined. The crank had been machined the last time and came still O.K. although the fiber thrush washer on the fylwheel side was totaly gone and laying in pieces. They did put in new main bearings. When I was down there last week the head was back on. They know we don't HAVE to have that tractor RIGTH NOW, so they work on it in between the rush jobs, and thats alright with us and it works out good for them. Thats why it is takeing so long. As of last week the bill had topped $5,000 so far. You won't have the labor bill, but you will still have the parts bill and the out side shop work bill. THE LAST THING YOU WANT TO DO WITH A 730D IS TAKE ANY SHORT CUTS. That is what ws done last time and we are doing it all over again.
Paul
12-21-2003 06:52:26
 Re: Re: Best place to get 730 Injection pumps redo in reply to MIKE HANLEY, 12-20-2003 13:36:36
Mike,
Yes, I have read some of your posts concerning your 2 730s. I can understand your frustration with poor workmanship done by others. Thats why we do all the work ourselves except for machine shop work or special services such as injection pump work. My dad was a diesel mechanic for 20 years, I'm a mechanical engineer, and we are farmers. We are fortunate for these experiences and have the skills and resources to do the work right - albiet I agree that parts are expensive now days.
Thanks for your post, good luck.
Moye
12-21-2003 06:17:08
Mike, do you know where they got their main bearings for the crank shaft. I am doing a 70 D and cannot find main bearings. Thanks, Moye
buickanddeere
12-21-2003 22:31:27
 Re: Re: Re: Best place to get 730 Injection pumps in reply to Moye, 12-21-2003 06:17:08
Albert at Renaissance Tractor has some source for main and center bearings on some two cylinder diesels. Check with him for specifics.
F-I-T
12-20-2003 10:56:48
I had Albert at Renaissance Tractor do my pumps, injectors, and fuel transfer pump for my �70�D. He did excellent work, on time and trouble free. He will ask that you send him the pumps on the pump bracket, and he will calibrate and synchronize the pumps, so all you will have to do is to bolt them down and set the timing.
Frank-in-LA
Paul
12-21-2003 06:53:55
 Re: Re: Best place to get 730 Injection pumps redo in reply to F-I-T, 12-20-2003 10:56:48
Thanks for commenting Frank. If you don't mind me asking - what was the cost?
F-I-T
12-22-2003 07:50:45
 Re: Re: Re: Best place to get 730 Injection pumps in reply to Paul , 12-21-2003 06:53:55
Paul:
Send me an e-mail and I'll give you the details. I don't want to price Albert's work here.
Just send it to [email protected]
Frank
