4020 pto noise
dave
08-16-2002 19:41:49
When using a haybine and round baler, there is a very loud rattling noise in the cab when the pto is under load. No noise from the implements. Any ideas or suggestions? This tractor has the 540/1000 pto arrangement.
zane
08-17-2002 05:40:59
 Re: 4020 pto noise in reply to dave, 08-16-2002 19:41:49
Could be serious trouble, a bad bearing at the pto outlet shaft, or improper hook-up with the implement. If a bad bearing, it is probably leaking oil around the shaft.
Make sure the implement power shaft is operating in as near a straight line as possible. Much of an angle on a U-joint will cause a strain that often translates to a noise/vibration. Also make sure the power shaft is not pushing in on the pto shaft; i.e., power shaft is not too long.
