4010 Diesel plow capability
JD 4010 Diesel
08-16-2002 16:05:18
Would my '63 4010 Diesel pull a 5-16" plow? I will be plowing 10-15 acres at the county fair of grass and oat stubble. The ground is pretty much flat. My tractor is is a 4010 Diesel with a M&W Turbo and 16.9.38 rears without fluid and no weight on the rear. I can have up to 5 weights on the front. Also would I have a problem with the tractor overheating? Any help is appriciated. Thanks!
bigbadjohn88
08-16-2002 16:56:12
 Re: 4010 Diesel plow capability in reply to JD 4010 Diesel, 08-16-2002 16:05:18
You should be able to pull 5-16 with a 4010. But if the ground is very heavy you will need weight on the rear. I used to pull 6-16 with a 4020 but needed a lor of weight. 6-16 was an over load in our clay soils.
zane
08-16-2002 17:28:19
 Re: Re: 4010 Diesel plow capability in reply to bigbadjohn88, 08-16-2002 16:56:12
My 4020 was never comfortable w/ 4-16's at walking speed and a full bite. This in south Ga. Many clay (gummy) spots.
Steve J
08-16-2002 18:44:51
 Re: Re: Re: 4010 Diesel plow capability in reply to zane, 08-16-2002 17:28:19
My '72' 4020 pulls a 4-16 easy in central IL black dirt.
