620 fan shaft problem
Larry
08-16-2002 13:03:32
Just looked at a decent 620 this morning. Fellow wants to sell. He was using to move bales and fan shaft quit turning( noticed quickly as power steering quit also). I have not even had a chance to look at a parts book yet. What do you think? Is there a key in the bevel gear in govenor that could have come loose? Tractor does start and run pretty good but you could hear gov. noise and only ran about a minute.
Clooney
08-16-2002 15:05:28
 Re: 620 fan shaft problem in reply to Larry, 08-16-2002 13:03:32
Larry, usually the coupling that joins the fan shaft to the power steering pump fails or the rear fan shaft coupling. Unfortunately the splines on the fan shaft are usually torn up too.....
