Jd 70 regulator
Steve in ohio
08-15-2002 20:51:29
i bought a new regulator for my 70 and i hooked it up and it works ok. but im kinda curious about where the terminal that has the "L" on it is supposed to be hooked up. the diagram that i got with it wasnt the correct one for it. i remember reading not too long ago that someones diagram says its hooked up to the switch? if so where? i kinda thought it might be for an idiot light for the charging system and thats what my cousin who's a automotive mechanic thought too. so just wonderin about it. thanks
Steve in ohio
08-16-2002 10:55:09
 Re: jd 70 regulator in reply to Steve in ohio, 08-15-2002 20:51:29
thanks guys for helping me out on this. ill put some thought into this and decide what to do. thanks again.
Steve - IN
08-16-2002 13:05:06
 Re: Re: jd 70 regulator in reply to Steve in ohio, 08-16-2002 10:55:09
Steve,
Maybe the key is that the L connection on the regulator needed to be there to coddle the batteries available in the 40's and 50's. They're closer to Alessandro Volta's first pile than the things you get off the shelf today.
You said it was running OK. I'm guessing you're not doing 'round the clock planting or harvesting with it -- so lights aren't a big problem. Also guessing that the lights are drawing off the battery line and the battery or batteries in there are less than 5 years old. In that case -- why mess with it?
That's just the view from here at the lazy guy's school of wrench turning and deductive circuit troubleshooting. If you're from the fastidious guy's school of mechanics and correct restoration; then by all means use the L line as originally intended. Sad in a way that you probably can't find a new 1957 battery to appreciate your work. Those new DieHards just don't care anymore. (humor and puns always intended).
Least we all appreciate the spirit of the 70 if not always the obsolete details therein.
regards,
Steve
Steve in ohio
08-16-2002 20:11:02
 Re: Re: Re: jd 70 regulator in reply to Steve - IN, 08-16-2002 13:05:06
i guess i should've originally said that the regulator that was on it before had only 3 terminals on it and not 4. and im basicly going to do a cheap restoration on it (paint, engine overhaul ect.) for ffa and to use. then also, with factory fenders, and a bush-hog 3000 loader with hydrolic bucket, how much do you think this might be worth? i know fenders are really hard to get let alone factory originals that have no rust and no dents. it also has a charr-lynn power sterring unit added to it. thanks again for answering.
Clooney
08-17-2002 07:59:06
 Re: Re: Re: Re: jd 70 regulator in reply to Steve in ohio, 08-16-2002 20:11:02
Steve, if the original regulator was a non-current control with only 3 terminals then you probably have the late 70 as it didn't use the current control regulator & powered the ign/light switch from the non-battery side of the ammeter. In that case just leave the [L] terminal open.
~The early 70's had both a black [load] & white [battery] wire exiting the main wire harness to the generator & powered the ign/light switch from the black load wire. [carryover from the "A" era]
~If you only have the white wire at the regulator & are using the existing harness, just leave it that way. If you have a 4 terminal regulator [with L] & are going to build a new wire harness, just add a black load wire from the [L] terminal on the regulator to the [BAT] terminal on the ign/light switch & remove the jumper from the [BAT] terminal on the ign/light s/w to the ammeter non-battery side. [it's just that simple]
Steve - IN
08-16-2002 22:26:09
Steve,
Understand about the 3 terminal voltage regulator. My 60 only has three as well. That's why I was doing the mental gymnastics, trying to back in to what the terminal was for based on cars I've worked on. All the books I have on it are out in the barn with the bats and the raccoons at night, so I did it from memory.
Sounds like your 70 has all the trimmings! I've seen the fenders alone go for nearly 500 bucks on eBay -- even more for the flat top fenders on the 30 series. They may be worth more if you sold them separately. But then again people get in to bidding frenzies on eBay and at auctions, and sometimes they don't. You have to learn how to present them so people just can't bear to live without them.
Funny thing about number series JD tractors. The little 40's and 420's are going for as much or more than 70 row crops. But anyway... for wild guesses on prices... I'd start at 2500 to 3000 for a basic 70 in that runs and looks good here in Ohio, Indiana, Illinois. Then add a few hundred for the fenders and another few hundred for the power steering. The loader is the big adder. You might be able to get another 2,000 for that. Loaders are a hot item. Seems everybody needs one on their tractor. These are all guesstimations, you understand. There was a guy who posted on here a few days ago who had just bought a 70 with a loader. You might give him a shout and see if he'd care to share his views on pricing. I put in a link to his post below.
The downside to pricing right now is that farmers are looking at dry weather and low crop yields. Guys with hobby farms are seeing their 401K retirement accounts dwindle, so they don't feel as rich as they did a year or two ago. You might have read that retail sales were fairly sparse last month, and that people are doing a lot more shopping at WalMart than they are at any expensive stores. Old tractors like ours are more toys than tools -- so I imagine the prices are or will be affected. The good thing is that this is America, and hope springs eternal. Next Spring -- when tractors and lots of other things normally sell at a much better rate, and for higher prices --you could be looking at a completely different story.
I'm guessing you're also thinking about getting a sharp car or truck, maybe going to college, and all the other fun hopes and dreams a guy has when he's in FFA. Forty years from now you might regret ever selling that 70. But for right now you want to do and experience as much as you can. So more power, and good luck to you.
P.S. I don't think they'll give you any grief in FFA about that L terminal. If they do, a good explanation of why it's there and why you decided not to use it should smooth it all over. Might also be a good exercise to figure out how it works inside. In the world we live in, where everything seems do-able with a few lines of digital code, the analog magic done in that little voltage regulator box with some coiled wire, a few springs, contact points and a resistor here and there is something to be respected, and the guys who designed those things are to be admired -- even if they gave you an L terminal you don't need. Somebody's 1950 vintage car with headlights, heater fan, windshield wipers, radio blasting and maybe an electric convertible top did need it. When all you have are two or three lights and maybe a cigarette ligther in your 70 pulling on a 2001 vintage battery, it's kind of doubtful.
take care,
Steve
Ol John T
08-16-2002 07:59:54
Steve, in line with what clooney told you, if the tractor originally was equipped for a voltage regulator that had the L terminal, the Bat terminal on the VR was connected to the load (non battery side) of ammeter, while the L terminal went to the switch to feed lights and ignition etc. all loads. If you change the wiring or system, you still need to feed power to the switch to power the loads, and in systems that had no VR with the L terminal, those loads then ran off the load side of the ammeter. Either way will work. Good luck, Ol John T Nordhoff in Indiana
Clooney
08-16-2002 02:40:08
Steve, the "L" [load] terminal is for any load excluding battery charging. The ignition, lights & any other load is usually hooked to the "L" terminal. ~The battery [only], is connected to the [BAT] terminal on the regulator through the ammeter .
~The main purpose of a separate "load" terminal is that it allows the [load] such as lights, ignition etc. to BY-PASS the current control winding in the regulator so the battery isn't overcharged due to added load on the current winding around the field control that would normally increase the charge rate .
~If you don't have an "L" terminal or don't want to use it, you can just hook the load wire to the [BAT] terminal on the regulator & the system will work just fine. You might get an overcharged battery if the tractor is worked for hours on end with the lights on, but for light use & most play use you won't notice the difference..... ....
Steve - IN
08-16-2002 00:57:16
Steve,
Here's some theory and a few thoughts from memory that may help sort it out.
There's gotta be a terminal for the field windings and another for the armature in the generator -- the generator being regulated by increasing or decreasing current flow to the windings by varying resistance inside the regulator. I think they're labelled F (field) and A (armature) on the Delco or JD regulator.
Then there's got to be a connection to the regulator's limiting circuit to prevent the battery from getting overcharged at higher RPM, and charged as much as possible at low RPM or heavy demand loads. That's connected -- strangely enough -- to the battery by way of the amp meter. I remember it being labelled B, for battery. That's three terminals, and so far we should be tracking to the way your 70 is setup.
From messing with other regulators on other machines, the most I remember are 5 terminals. The first was labelled G for Ground (or E for Earth on British iron). The second terminal is a subset of the battery charge limiting circuit - B. It's variously called AI, I (for indicator on a Ford I remember), or B1 / BI for battery indicator, etc. Also, this line in some older cars runs to the head and tail lights as well as the idiot light because keeping the lights bright and the battery charged is one of the most important jobs a car's regulator has at night. If you run the lights through the regulator's limiting circuit it's easy to compensate for both night and day driving - and the different charge levels the battery needs in both circumstances. So I'd put my money on L = lights. Of course it runs to a switch, like you say, for the head and tail lights. It can also run unswitched to an idiot light so you can see what's happening to battery charge in the daytime. I think I've stumbled into the truth there. We'll see what other guys say.
Whatever the case, ammeters are better than idiot lights, and 70's came with two batteries. If the L terminal is designed for 40's and 50's vintage cars running one old type battery -- trying to balance things out between night and day driving -- it doesn't really apply to your 70. So it ain't broke, and I'd advise against tying to fix it by messing with that L terminal
Steve
