Change 620 from generator to alternator
Dick
08-14-2002 20:57:06
Do I need a special alternator or will any one work?
Also, any special problems in the changeover.
Thanks.
JD60
08-15-2002 19:05:24
 Re: change 620 from generator to alternator in reply to Dick, 08-14-2002 20:57:06
I dont know if this will help but on my 60 i had an alternator that come off a toyota that fit perfect. Then heres the downside it took an ext regulator. But i went to a local automotive electrical place that repairs starters and such. They gave me a very simple regulator. One wire to the field of the alternator one to the battery post and one to the ignition. Charges perfect.
Clooney
08-15-2002 03:36:09
Dick, it depends on how much work you want to put into it, & what you have access to?
~The easiest to install is a 1 wire Delco alternator as it only needs one wire hooked to it. The down sides are cost [it is more expensive], those 1 wire alternators usually need more RPM to initialize after start-up so the engine usually has to revved up after start up [being a 620 that runs faster helps that problem] & if the tractor is stored for long periods the regulator will usually have to be jumped to get it to charge the first time after storage.
~Probably the most widely used, easiest to obtain & cheapest route is to use a Delco 10-SI from a mid 70's G.M. car or truck. They are everywhere, fairly easy to install, work good & store well.
~Your other options are Ford, Deere & Chrysler type alternators as well as the imports, but those are harder to install, harder to find info on & some need additional hardware.
~My personal recommendation for tractor use is the old conventional Delco 10-SI alternator in the under 55-60 AMP output configuration [the 60 amp & up outputs will require heavier tractor wiring & impose unwanted additional wear on the fan gears]. ~Installing the Delco 1 wire amounts to cobbling the mounting bracket slightly & cobbling the adjusting strap slightly , installing a different belt & just extending the battery wire at the regulator & hooking it to the [BAT] terminal on the back of the alternator, [most 1 wire alternators are 60+ amp output & SHOULD have the battery wire from the alternator to the ammeter & battery up-gauged to a heavier gauge wire].
~Installing the Delco 10-SI conventional, amounts to the same mounting bracket & adjusting strap modifications & the addition of a resistor & diode in a second wire from the ign switch to the alternator #1 terminal. ~Let me know which way you want to go, & if you want to use a conventional Delco 10-SI or Delco 1 wire & I will E-Mail you a wire diagram....
Anthony Arnold
09-15-2005 07:24:51
 Re: Re: change 620 from generator to alternator in reply to Clooney, 08-15-2002 03:36:09
I have a 3414 International tractor, I wish to convert to one wire alternator. Could you give me some information and a wiring diagram, if you have one.
Thanks for your time,
Anthony Arnold
(417)548-2021
Wentworth MO
william mcclain
07-05-2005 10:40:42
 re farmall super M in reply to Clooney, 08-15-2002 03:36:09
I am change from generator to alternator on a farmall super M. I want to get rid of the old voltage regulator . where should the wire be run thank william
Bob K - I need a 10-SI wiring diagram too
08-15-2002 05:07:59
I'm repairing a 10-SI system on a 720 and would like a wiring diagram for it. Please e-mail me a copy. Thanks Clooney.
Clooney
08-15-2002 13:50:11
 Re: Re: Re: change 620 from generator to alternator in reply to Bob K - I need a 10-SI wiring diagram too, 08-15-2002 05:07:59
Bob, check your E-Mail..... ..... ..
