Governor noise, jd B
dale t
08-13-2002 19:42:47
After putting in new gaskets I have a howl in the gears. The gears are the same ones as before. Is it possible to quiet them again? Too tight maybe? Can they be adjusted on the left side plate? Thanks alot!
Clooney
08-14-2002 02:24:07
 Re: governor noise, jd B in reply to dale t, 08-13-2002 19:42:47
Dale, what gaskets did you replace? ~The governor to fan shaft & the LH governor cover gaskets are really shims & the thickness needs to be the same as removed or the governor will have to come off to get access to the bottom to visually re-adjust the fan gear heel alignment & re-set the backlash..... .
Dwayne
08-13-2002 20:00:04
it sounds like you have your gears too tight. How much play do you have in the fan? you should be able to move it about 1/4 inch.
