730 Pony Engine
Mike Behr
08-13-2002 19:27:54
Pony engine makes "spongy" starts. Starts promptly but very quietly and takes a few seconds to get up to speed. Almost cannot tell if it is running with the starter still pushing it. Electrical system thought to be OK, but carburetor settings do not seem to have much effect. Are ponies supposed to kick off like "real" engines, or is this just the way they are?
Clooney
08-14-2002 02:30:51
 Re: 730 Pony Engine in reply to Mike Behr, 08-13-2002 19:27:54
Mike, mine is the same way. I have my base idle set a little low so that is probably the result.
~Just let up on the starter button once it cranks for a second to see if it's running [it probably is]. ~The base idle is supposed to be 4000 RPM which is pretty fast & if set lower won't let you know it's running until it runs long enough to speed up a little.
720x3
08-13-2002 21:23:40
Mine is that way until it warms up a bit., Which is good.Those motors are VERY EXPENSIVE to rebuild if you should happen to throw a rod...Best to let them warm up slowly
Duane(Pa)
08-13-2002 20:16:15
Thats the way mine runs, lots of flywheel to get moving on those mouse motors.
