John Deere 50 gears
Richard
08-13-2002 14:07:16
I need help with my newly acquired JD 50. Sometimes when I put it into either 3rd or 5th gear nothing happens. Then after I run the shift lever through some of the other gears I come back to 3rd and all works perfectly. Is there a simple solution to this problem. I hope so because I'm not much of a mechanic. Thanks
Clooney
08-13-2002 14:33:47
 Re: John Deere 50 gears in reply to Richard, 08-13-2002 14:07:16
Richard, because 3rd & 5th are different gear sets I believe your problem isn't in either 3rd or 5th but more than likely in the overdrive under drive gear set. Your problem is kind of common on high hour tractors, or tractors with worn bearings, or worn shift rails or worn shifter.
~Unless you are lucky enough to just have a shift rail adjustment problem, you will have to tear into it to find the problem. You will need a service manual & some basic mechanical knowledge to make any adjustments or repairs & shouldn't even consider it without a manual & thorough understanding of how the transmission works.
~Until you get the time or absolutely need to go into the trans, you might try a slower more deliberate shift & MAKE SURE the pulley is spinning SLOWLY during the shift, especially when going through the gate from one side of the shift quadrant to the other. In many cases that will allow the underdrive/overdrive to engage almost every time...
