Clooney
08-13-2002 08:58:23
Re: JD50...Not charging in reply to Vito Petruzzelli, 08-13-2002 07:24:06
Vito, start by making sure you have battery voltage at the [BAT] terminal on the voltage regulator, if not find out why & repair that. ~Then with the engine off, ground the [F] post on the generator & jump power from the [BAT] terminal on the regulator to the [ARM] post on the generator [larger of the two], you should see a spark. That will polarize the generator correctly. ~Then with the engine running at fast idle see if it charges, if not, ground the [F] post on the generator & see if it charges, if so you have an open in the field wire from the regulator to the generator, a bad regulator ground ,or a faulty regulator or generator. ~If it still doesn't charge, leave the [F] post grounded & jump the [BAT] terminal on the regulator to the [ARM] post on the generator & see if it charges, if not you probably have a generator problem [or the ammeter is connected incorrectly]. ~To test the generator, make sure you have battery power at the regulator [BAT] terminal, then remove the fan belt from the generator, then remove the [F] wire at the generator, then jump power from the [BAT] terminal on the regulator to the [ARM] post on the generator [the generator should start to motor, then reconnect the field wire, the generator should slow down. If not ground the [F] post at the generator to see if it slows down�If it motors & slows down the generator is probably good, if it motors & doesn�t slow down you probably have a bad field & if it doesn�t motor at all the generator is probably bad. ~If the charging system checks out ok, make sure you have the ammeter wired correctly. The wire running from the ammeter to the regulator MUST not be connected to the same side on the ammeter as the battery wire from the battery or starter, there should only be ONE wire on the battery post of the ammeter.. ~If at ANY time you connected or even touched battery power to the [F] terminal on the regulator suspect a bad regulator���
