JD 2 bottom plow model number
Wayne Wiseman
08-12-2002 17:33:58
Could someone tell me the number of a 3 point hitch, slat moldboard, 2 bottom, 12" plow. The best I can make out the number is a 3 digit number starting with a '4'. Want to paint the plows and put JD decal with the number of the plow. Thanks.
Bill
08-13-2002 03:48:24
 Re: JD 2 bottom plow model number in reply to Wayne Wiseman, 08-12-2002 17:33:58
Most likely it's a 412. The 411 was the early 1 bottom 3pt plow, the 412 was the 2 bottom. There is currently a 411 on the photo ads section. These plows did not have trip bottoms. A 415 would be a little bit newer, 2 bottom, 3pt with trips. The furrow wheel on a 412 was painted green. I've got a 411/412 OM at home if you need info or the # to order one.
Alan Johnson
05-10-2004 15:05:56
 Re: Re: JD 2 bottom plow model number in reply to Bill, 08-13-2002 03:48:24
I have a JD 415 two-bottom moldboard plow which I have restorded (sandblasted primed and painted). Also have a restored JD P75 integral disk tiller and a unrestored culivator along with a set of front end weights. The culivator is JD but local JD people cannot find numbers, etc. All for 1954 JD 40U which I have also restored. Do you have any idea as to value of any of above or any idea of number for culivator?
Thanks for any help you can give.
Alan
Wayne Wiseman
08-13-2002 16:34:16
Thanks for the info. My JD plow is a 412 based on the picture received from Bill.
Wayne Wiseman
08-13-2002 16:34:02
Richard
08-12-2002 18:58:39
Need to get a reference book. Green Magazine has been running plow article for the last eight months with pictures and discriptions. Paint is a no brainer, all green with usual yellow furrow wheel. Moldboard fronts were bare. But a period picture would show were to place decals, this is how I restored my M-21A plow.
