3020 Diesel Injector pump no longer available?
BIG JOHN
08-12-2002 15:47:08
whats the deal? went to deere and parts guy said a pump for my '66 is N.L.A. now what? anyone gotta pump? parts to rebuild available? what? no enough 3020's still out there? Is the parts guy wrong? Trade for an IH? as you can see I'm not happy! as far as I can tell there are thousands still out making money.....
BIG JOHN
G-MAN
08-13-2002 10:28:17
 Re: 3020 Diesel Injector pump no longer available? in reply to BIG JOHN, 08-12-2002 15:47:08
If you don't want to wait to get the old one rebuilt, most competent injection shops will have a rebuilt unit on the shelf on an exchange basis. That will save you some time. I also strongly suggest pulling the nozzles and having them tested at the same time. The best pump in the world can't make faulty nozzles perform well, and new or rebuilt nozzles for your 3020 should be relatively inexpensive.
John
08-12-2002 16:59:24
You need to get it rebuilt. Instead of taking it to the dealer take it to a good pump shop. It is a Roosa-Master/Stanadyne pump and they can still be worked on with no problem, they are a very common pump. It will probably cost you(they aren't cheap to fix) but you will have a beautifully running tractor again. Where are you from?
John
BIG JOHN
08-13-2002 04:00:40
 Re: Re: 3020 Diesel Injector pump no longer available? in reply to John, 08-12-2002 16:59:24
wisconsin
Dr. Evil
08-13-2002 07:44:13
 Re: Re: Re: 3020 Diesel Injector pump no longer available? in reply to BIG JOHN, 08-13-2002 04:00:40
Try Diesel Injection Service in Sun Prairie, WI NE of Madison about 5 mi. on Rt. 151 608-837-7358
CASEPOWER
08-12-2002 16:02:39
Hey, I have a 3010 diesel I am parting it had two bad pistons, but the pump was good and been taped up since torn down. I also have the lines. I am not sure if 3010 3020 is the same. E-mail me and I will get you the #s..
twopop
08-12-2002 18:00:36
 Re: Re: 3020 Diesel Injector pump no longer available? in reply to CASEPOWER, 08-12-2002 16:02:39
the pumps arnt the same
