Gettin' Ready to Finally Pop
Mike O
08-11-2002 17:04:19
After a 25 year rest, my 48 A is about ready to pop again! I'm pretty excited as it's been about 3 years since I started tearing it down. I don't have any of the sheet metal done yet, so I don't have the hood or gas tank on. What's the best way to set up a temporary gas supply so I can at least get it started and run for a few minutes?
Any other advice before I give it a pop ???
snowmantn
08-12-2002 05:39:14
 Re: Gettin' Ready to Finally Pop in reply to Mike O, 08-11-2002 17:04:19
Mike, on my '51 A I used the large bolt under the rear of the gas tank to attach a piece of flat iron bent so it would hold an old lawnmower tank off to the side a little. The tank I have came off one of my father-in-law's old riding mowers. This set-up works great just like F.I.T. said. Good luck with your A!
snowmantn
Danny JENNINGS
08-12-2002 18:22:25
 Re: Re: Gettin' Ready to Finally Pop in reply to snowmantn, 08-12-2002 05:39:14
GET OLD GAS CAN, ATT. HOSE (MAKE SURE GAS DON'T LEAK FROM HOSE ) ATT. TO INLET PORT OF CARB ( SURPPORT CAN PROPERLY) CHECK ALL ELEC,WATER,ECT. FOR LEAKS ,LOOSE WIRES ,FITTINGS AND GO FOR THE POP!!!!
Tractorboy
08-11-2002 17:32:44
I took a 1 gallon metal can and brazed me a fitting on the top and cut me a hole in the bottom and clamped it to the steering post and run a line to the carb. Works fine and inexpensive to make . I got one ready to do the same thing on.
F-I-T
08-11-2002 17:17:24
Mike O:
I keep on old plastic lawn mower tank handy for just such occassions. It even has an in-line filter. At around one quart, it will let you give her several minutes of run time, and if you tip it over, you don't lose all that much.
Frank-in-Tallahassee
70D // 855
