JD A carb settings
CAM
08-11-2002 15:33:51
I have a JD A bored 125 over, stock cam, stock heads but they have been rebuilt.Was wanting some idea where to start with carb. adjustments?Need help and ideas. Thanks . CAM
Clooney
08-11-2002 15:38:36
 Re: JD A carb settings in reply to CAM, 08-11-2002 15:33:51
CAM, start with the idle needle 2 turns out from seated & the load needle 1 turn out from seated & adjust from there when warm.....
CAM
08-12-2002 18:35:48
 Re: Re: JD A carb settings in reply to Clooney, 08-11-2002 15:38:36
thanks.we seem to be running better then we have in awhile. while testing today i was riding the breaks,friend said not to do this , might break axel? what u think .U R a big help
Clooney
08-13-2002 02:24:07
 Re: Re: Re: JD A carb settings in reply to CAM, 08-12-2002 18:35:48
Cam, you won't break an axle but will glaze the brakes & turn the drums a funny black color from heat build up.
~Try to find a long steep hill to climb, I like to pull my tractor hauling trailer with a tractor on it while climbing a long hill. Or hook up to a Baker fan..... .
