JD 720 stuck in 2nd gear
Vince
08-11-2002 14:35:31
Recently purchased a JD 720. In between post holes I went let the clutch out and the tractor stayed in 2nd gear. I shut down the tractor and now I can't move the hand clutch and it is still in gear. Please give me some advise where to start. I have all the manuals and want to tackle this project myself.
Woodman
08-11-2002 16:51:09
 Re: JD 720 stuck in 2nd gear in reply to Vince, 08-11-2002 14:35:31
Mine did the same thing and I pushed down hard on the shifting lever while trying to shift it to another gear. I was able to get it unstuck this way. The tractor was running when I did this. Then I took the shifter off and realined the shifting rails. Also I had A bent shifting lever which I repaired. It worked good then. You might want to check past posts on shifting problems. There was A lot of good info that helped me.
