? new generation rowcrop vers.standard tread ?
Mike M
12-19-2003 07:36:49
I'm from where about all the tractors are rowcrops. I see a lot of standard tread 4020 and 3020 tractors for sale up north and northwest. What advantages did these tractors offer for your type of farming ? I also see 2 cyl. 620 and
70 standards these tractors offer the same horsepower as there rowcrop versions.Why not just
add a wide front end to a rowcrop ? I have to think I'm overlooking a special need otherwise they would not have been built ? Friends up north help straighten me out. Thanks in advance.
MIKE HANLEY
12-20-2003 01:39:33
 Re: ? new generation rowcrop vers.standard tread ? in reply to Mike M, 12-19-2003 07:36:49
Thats a good question. Other then thats what the guys wanted out there. Goes back to the old "D's I would guess. The last true standard, other then the R/830's was the early 60. and that was changed over to a rowcrop with a standard WF and standard fenders beore it was discontinued. From then on again other then the R/830's the standards were nothing more then rowcrops with the standard WF and standard fenders. When you think about it, the standard WF wasn't any stronger then the rowcrop WF's as the weak point in both of those WF's were the spindals and the tierods. As to addeing extra weight to the front end the shipping weight wasn't that much more then the rowcrop and if you put on a rowcrop WF on a rowcrop and added front end weights you were above the weight of a standard. And when it came to servicing things like brakes and things, the standard fenders were nothing but in the way. When I was cowboying in Wyoming in 59, 60 and 61, the ranchs in that area were all rowcrow tractors. The standards were up in the wheat country. I don't think there is an answer other then thats what the guys wanted and the demand was there. But it goes along with why when the 60's and 70's were in production with live hyds and live PTO, why was there still a demand for the old "D" so that JD made up 97 more "D"'s in the street outside the factory. The demand was there.
Mr. Greenjeans
12-20-2003 06:06:42
 Re: Re: ? new generation rowcrop vers.standard tre in reply to MIKE HANLEY, 12-20-2003 01:39:33
I think you'll find it was 92 Model "D" tractors, Mr. Hanley
Russ
12-20-2003 09:22:30
 Re: Re: Re: ? new generation rowcrop vers.standard in reply to Mr. Greenjeans, 12-20-2003 06:06:42
92 D's: If that was the ready for shipment numbers of this Classic tractor, I don't know.
Fact is I may know very little about tractors
compared to the loads of talent on this website.
But the JD D of that time was solid, handsome,
a mean pullin' machine and I too would like to have one in spite of small acreage in these parts.
Ah yes, the demand for a Classic.
Mr. Greenjeans
12-20-2003 18:18:23
 Re: Re: Re: Re: ? new generation rowcrop vers.stan in reply to Russ, 12-20-2003 09:22:30
What Mr. Hanley was referring to was the 92 "Streeter" Model "D" tractors that were built with hand tools in June and July of 1853 after the Model "D" production line had been shut down earlier in 1953. There were 92 of these tractors built, not the 97 that Mr. Hanley stated.
rob nickel
12-21-2003 10:18:37
 Re: Re: Re: Re: Re: ? new generation rowcrop vers. in reply to Mr. Greenjeans, 12-20-2003 18:18:23
These must be some of the most rarest of D's built then seeing there were so few. Any idea what the numbers were for these D's or what there worth by now? If in fact any of them are still around somewhere?
Ralph
12-19-2003 13:25:34
Row crop cultivators were commonly mounted on the front end. Beyond the corn growing limits standard tread tractors were quite common.
