Best way to use Dupont metal prep 5717 process?
scott#2
12-19-2003 07:25:03
After you have wire wheeled down all the rust on the sheet metal and start using metal prep, is it usually assumed that, if you scrub with a scotch bright pad and the prep solution, that discoloration from where the rust used to be is left behind or should you be left with shiny metal? Does anybody have a treatment process that has yielded good results? What is an adequate scrub time, rinse process and drying time/ process to insure rust wont come back later? Basically whats the best way to use this stuff and what shuold I expect for the efforts? Any help is greatly appreciated.
scott#2
Clooney
12-19-2003 09:44:55
 Re: Best way to use Dupont metal prep 5717 process in reply to scott#2, 12-19-2003 07:25:03
Scott, you are doing the correct thing by treating your metal with a Metal Prep solution,, that will kill most of the rust in the metal pores..
~There are many ways to use Metal Prep but by far your best bet is to follow the directions written on the can, or on the DuPont web site..
~You can just spray the Metal Prep on & let is sit for a while, then wash it off with clean water... That will leave a coating of iron phosphate & that will protect the metal for a while.. You can also use the Scotch pad method & that will work the Metal Prep into the metal pores farther & loosen any loose rust or surface rust... You still need to rinse it off with clean water [follow DuPont's directions].. By using the Scotch pad you will get a little shinier metal surface & the iron phosphate outer layer will be thinner..
~What I [usually] personally do is sand blast or wire brush, then treat with a good wet coat of diluted Phosphoric acid [same a Metal Prep only cheaper], then re-sand blast or re-wire brush, then hit it again with a light coat of Phosphoric acid, then wash with water, dry, & prime..
~In a lot of cases I use Vinyl Wash as the first primer coat & that binds better if the surface has a little surface rust on it, the last water wash after using the Metal Prep leaves a good surface for that after it dries...
[email protected]
