Cleaning brass tag
Randy
12-19-2003 06:58:18
What is the best product to use on cleaning the brass tag serial number on a tractor? I've used brasso, but it didn't really bring out any shine. Also, what can you put on it after you polish it to protect it from tarnishing again? Thanks, Randy
CPeter
12-20-2003 08:56:47
 Re: Cleaning brass tag in reply to Randy, 12-19-2003 06:58:18
I use a product called Nervdull. Comes in a can at the hardware or auto supply store. Starting using it 35 years ago in service. Will also take scratches out of plastic(sometimes) and remove old lacquer from brass. I used it for many things.
CPeter
Randy
12-19-2003 13:34:08
Thanks again for all of the suggestions. I'll give them a try. Randy
Bguy
12-19-2003 11:48:26
Randy, I have had real good luck cleaning brass tags using the brass cleaner that I use when tumbling ammunition cartridges, I put some on a piece of 000 steel wool and polish it. It will get real bright and shiney. I then degrease it real good and spray it with clear polyurethane to keep it from turning. I have two B's I did this to a couple of years ago and they still look great. I would like to paint the recessed areas black but my painting skills aren't up to that task. I have seen some done like that and they look sharp.
Mike Aylward
12-19-2003 11:11:29
Randy, I have heard that toothpaste works well on brass. I know it works great on silver. Might be worth a try. Mike
tom
12-19-2003 14:14:19
 Re: Re: Cleaning brass tag in reply to Mike Aylward, 12-19-2003 11:11:29
Is that regular or spearmint??
Henry J
12-19-2003 10:16:35
Randy
To protect shined/polished surfaces, I use a can of stuff that my wife has in her hobby supplies. The label on the can indicates that it is clear laquer.
Mike M
12-19-2003 07:13:09
I think I have used steel wool and or some real fine wet sanding then I hand paint the areas that were originaly black then clear coat with some cheap clear in a spray can. One time my clear soaked into the black and ruined it. Some brands
are not compatible.
