John Deere LA Rusty Tag
Clayt
08-10-2002 06:42:10
I have a war-time LA. The tag is so rusty I can't read any digits. So far, I've only rubbed it with my rough old finger. Does anyone have any suggestions on how I can determine the serial number. The engine number is 51999. I hesitate to remove the tag because of damaging the rivets. Any help would be greatly appreciated. Clayt
Slofr8
08-11-2002 06:01:09
 Re: John Deere LA Rusty Tag in reply to Clayt, 08-10-2002 06:42:10
Clayt, I removed as much rust as I could with navel jelly ('43 B) then sprayed black paint on it and wiped it off right away. Some paint stayed in the numbers and I was able to read them.
JDM Guy
08-10-2002 10:52:48
Use sand paper. The numbers wont come off. I did that to all my tags.
Clayt
08-11-2002 11:16:36
 Re: Re: John Deere LA Rusty Tag in reply to JDM Guy, 08-10-2002 10:52:48
I used JDM Guy's advice. The numbers appeared like magic! 10638. Makes me one happy camper. Now I feel more like going to work on it. Much obliged. Clayt in Ohio
Tractorboy
08-10-2002 09:47:04
If you keep rubbing it more will come off , take a pencil and rub it over and sometimes it will come up, maybey a majic marker will help too. If not those nails will back out and u can get new ones ,as sometimes you can make the # out from the back side of the tag . Good luck
