Dual tandem trailer
ChuckW
08-10-2002 04:32:11
local bank had a repossed 1992 Trailer World dual tandem trailer 20' with a 4'dove. Trailer needed all rubber and appeared to have a leak at one of the bearing, believe these use a fluid oil system. Also deck needed work, and hook looked like an older type system. Needed painting. Looked like the trailer needed a restoration. Anyway I bid a little over $2000 seeing as it looked liked it needed about $1000-1200 spent on it. I didn't get it and am not too sorry. Does anyone know what a good used(not money pit) trailer like this sells for. In a heavy trailer I believe I wonder if it wouldn't be best to have a 24' .
Mike Aylward
08-10-2002 19:46:10
 Re: dual tandem trailer in reply to ChuckW, 08-10-2002 04:32:11
Chuck, I can't offer a guess on the trailer without really seeing it, but as far as length goes if you are counting on hauling tractors a 20 footer is kind of an awkward length. You can haul two narrow front tractors by "sandwiching" the front ends but if you want to haul them straight a longer trailer is in order. My trailer is a 25' deck plus 5' tail and works very well for two tractors parked normally and makes it easy to chain them down. My humble opinion. Mike
