John Deere Model 32 Hay conditioner
claude daniel
08-09-2002 19:29:35
I bought this used unit to cut my drying time. The used equipment dealer I bought it from knew what it was but wasn't sure how to use it.
Should wind rows be made or should I just go in behind the cutter wind rows from the drum cutter.
How much pressure is needed on the rollers?
How low to the ground should it be set?
How much ground speed?
This type unit was made in the mid 60's.
latta
08-10-2002 12:12:16
 Re: John Deere Model 32 Hay conditioner in reply to claude daniel, 08-09-2002 19:29:35
I have the operators manual for 22 and 32 hay conditioners. Can copy and mail it to you.
JD70Jim
08-10-2002 11:00:32
More than 25 years ago, my father used a #32 crusher to condition hay. We were using an old #5 mower to cut the hay and following one pass later with the crusher. The hay needs to be laid FLAT>>>>>NOT WINDROWED<<<<< for the crusher to be able to use it's crushing rolls properly. I think that the crusher would plug if used with windrowed hay. Both the #5 and the #32 were 7' cut machinery, thus the swath widths matched.
Properly cut, we were able to cut more than a day off of curing time compared to another farmer who used a mo-co at the same time. I can remember cutting one field and seeing him off to the south, also cutting. We baled the next day, but the neighbor's hay wasn't ready, and that night it rained. I remember it especially well because he came around and asked us how it was that our hay was ready and his wasn't!
I think that at the time the #32 was built, the currant production JD sicklebar mowing machines had a provision to hook up the #32 directly behind the mower with the pto coupled through the mower itelf. We couldn't do that with the old #5.
