JD 430 with a bent axle
Tony Ayotte
08-09-2002 18:01:13
my JD 430 was hit by a car before i bought it i have fixed all other damage but the axle. i have a rearend from a jd m without tearing both apart and looking would they be the same thing i would appriciate any coments thank you TONY
Jeff's 40
08-09-2002 20:39:22
 Re: JD 430 with a bent axle in reply to Tony Ayotte, 08-09-2002 18:01:13
Tony,
From what my books show me I doubt that the M Final drives will work in the 430. You would be better off finding a junked 40 to get your parts from if you couldn't find a wrecked 430 or 420. The 40 parts manual shows some of the same part numbers as the 430/420. If you decide to swap parts from differant tractors get yourself the parts books for both tractors. They will save you a lot of time and help determine what parts are in what tractor.
Good Luck at what ever you decide and have fun.
Jeff
Henry J
08-09-2002 19:04:03
Tony
My guess would be no way, but I don't have an M parts manual to compare. I think you have to isolate what type of axel you are looking for also, like what type rims, length of axel, etc. Good luck.
