520 all fuel carberrator (DLTX 96)
520lover
08-09-2002 17:23:50
The DLTX 96 was the correct carb for the all fuel 520 the what was the gas carb on the 520. I may have an all fuel It is a marvel shroader (SP)DLTX 96 and it has two more numbers after it. The number is on a round dime size plate on the top of carb. Is this the DLTX 96 or what. Also the 520 all fuel in the operators manual shows a fuel shutoff on the bottom right corner of the dash. Did the gas burners have the hole there and the "F"& "G" of was this just on all fuels? Mine has the hole and letters but NO rod. Thanks you al
Tony M
08-10-2002 11:21:57
 Re: 520 all fuel carberrator (DLTX 96) in reply to 520lover, 08-09-2002 17:23:50
I have a 520 All-Fuel, and it is missing the rod for the fuel shut off also. All the tractors had the hole and letter on the dash, gas or AF. The question is, does it have a three way valve and have both tanks? If you're trying to determine if you have an all-fuel tractor or not, I had a list of the serial numbers handy, let me know. If needed I can read the DLTX number off my carb. Hope taht may have helped.
Tony
Steven M
08-09-2002 18:53:35
Yes the 520 Gas has the hole with the F & G, But not the rod.
SEAMO
08-09-2002 18:19:43
(DLTX---96 520,530, all fuel) (DLTX---99 520,530 gas) INFO from Deere Carb Manual SM 2024 page 10--5--5. I hope this helps. Earl
