How can I get a shorter 620 muffler
Andrew Reinhart
12-19-2003 06:18:36
Hello, I have a quick question. I have a 620 john deere and i park it in a garage. The muffler is too short. It is one of those oval bodied muffler. I checked at a few places, but everyone only sells replacement mufflers, not shorter ones. I need the muffler to be about 3 to 4 inches shorter than stock. There isn't enough pipe sticking out above the muffler to cut enough off. And, it has a square 4 bolt flange/base that bolts to the tractor, so I can't just clamp on a regular muffler. Can you buy just the flange somewhere and then weld it to another muffler or something like that? Thanks for your help. I appreciate it a lot. Andrew R.
Loren - Minnesota
12-20-2003 00:24:17
 Re: How can I get a shorter 620 muffler in reply to Andrew Reinhart, 12-19-2003 06:18:36
Unless you want to keep everything looking original, here's what I did on my 60. Had the same problem. Cut the top of the oval muffler (approx. 2 in.). Replaced the front 600x16 wheels with 15" wheels from a JD 953 wagon and put low profile tire on. Clears the garage by about 1/2 inch.
Gordon
12-19-2003 18:03:44
If you can use one 20 inches tall e mail me, Ican tell you where to get one.
RB70D
12-19-2003 13:33:38
I have found that everytime I shorten a muffler the exhaust will be forced out below the mounting flange of the muffler.
Hoppy
12-19-2003 06:50:02
Check at your JD dealer and ask for specs on a muffler for a styled AR they are shorter, I don't know if it would be enough.
Mike M
12-19-2003 06:44:08
The factory did make a exhaust that went out of the manifold then down and out the back. You may be able to find a picture and pattern one after that.
guest
12-21-2003 11:45:43
 Re: Re: How can I get a shorter 620 muffler in reply to Mike M, 12-19-2003 06:44:08
I worked for a dairy famer who had a 620G with a loader who wanted to use it to clean out the bank barn and he found the exhaust that comes out the manifold, goes down and back and ends under the rear axle. I seem to remember that the muffler was either under the block or nonexistent.
