John Deere 60 engine bump Clooney please help!!
Chris
08-09-2002 13:44:18
I have a 56 john deere 60. I dont think i have a problem but i just want to make sure. When i throttle the engine up from about 450 rpm to about 650 rpm. it makes alittel bump noise i really cant tell where its coming from. I thinks its just an echo i checked the flywheel its tight checked the crankshaft end play its fine and like i say once past about 650 rpm you dont here it and it makes no difference whether the clutch is in or not. It runs perfect doesnt smoke its just that little noise. Its not very loud.I know that these old two cylinders do some strange things and make some strange noises sometimes. I have also pulled the inspection cover and checked the rod bearings. The engine had just been overhauled when i bought it last september. Thanks Chris
TOM
08-10-2002 11:03:00
 Re: John Deere 60 engine bump Clooney please help!! in reply to Chris, 08-09-2002 13:44:18
CHRIS THE CRANK IS WORE-OUT ON FLY-WHEEL SIDE,EVEN THOUGH THE FLYWHEEL BOLT'S CHECK'S OUT TO BE TIGHT. HAVE MACHINE SHOP BUILD-UP SPLINE AND RE-MACHINE.
Watchdog
08-10-2002 16:07:07
 Re: Re: John Deere 60 engine bump Clooney please help!! in reply to TOM, 08-10-2002 11:03:00
Wow! Tom you are sending him off to spend a lot of money. You are amazing to be able to tell he needs all that expensive work without even seeing the tractor. Do you tell fortunes and predict earthquakes too? Maybe you should read his post above about what he found.
Bill
08-10-2002 05:27:20
Sounds like pre ignitcion to me try high test gas
Chris
08-09-2002 15:34:27
Clooney, Its not like pans rubbing together its kind of a hollow sound. Its kinda there then gone. Its like a bump bump bump. then gone. Just for a second or less. I have a straight pipe on the tractor. Its kinda like the cyliders firing. I dont think i have an exhaust leak but maybe thats something to check. It is kinda like its lugging but the strange thing is its only a second. I appreciate your help clooney
Clooney [new]
08-09-2002 16:08:58
 Re: Re: John Deere 60 engine bump Clooney please help!! in reply to Chris, 08-09-2002 15:34:27
Chris, again, I can only guess without actually hearing it. A hollow bumping or thunking sound can be excess piston clearance to cylinder wall, [when running no load, the pistons just kind of lays on the cylinder bottom & when a load or quick burst of acceleration is applied they lift off the cylinder due to rod angle & cause a thunking sound.
~First get a muffler on it so you can hear abnormal engine sounds, then use a fairly high gear & go climb a steep hill, try different engine RPM's & see if you can duplicate the noise, if so there is a good chance you have piston slap. If it turns out to be piston noise [this is just a WAG] you probably still don't have a serious problem, there are many many 2-cylinder tractors running every day with piston noise & unless it is excessive it won't kill the tractor. ~Try running the tractor under load for about 1/2 hour & if the noise goes away or gets better it could be piston noise that gets better as the pistons expand. If it gets worse it is probably something different..... .
Clooney
08-09-2002 15:11:33
Chris, without hearing the noise it will be hard to give you a clear answer.
~Can you explain the noise a little more [e.g., 2 pans banging together or a low hollow sounding thunk?, or?].
~Do you get only a single noise or do you get multiple noises at throttle up?
