JUNE 14, 2004 PROBLEM SOLVED: I TOO HAD A PROBLEM WITH MY RECENTLY ACQUIRED 3020. THE TRACTOR WOULD STALL UNDER CONDITIONS THAT REQUIRED IT TO LOAD UP. I COULD NOT EVEN USE THE BREAKS FOR TURNING. WE TRIED MANY ADJUSTMENTS AND HAD NO LUCK. I WAS BEGINNING TO REGRET HAVING BOUGHT THE BEAST. THE PROBLEM IS SOLVED AND THE SECRET IS THE CHOKE. AFTER HAVING REMOVED AND CLEANED THE GAS TANK, THE CARBURETOR, AND FUEL LINES, AND HAVING A MECHANIC REBUILD THE CARBURETOR AND STILL HAVING THE SAME PROBLEMS I WAS DISCOURAGED. WHEN I PICKED THE TRACTOR UP AT THE MECHANICS SHOP, I MADE IT ABOUT 30 YARDS DOWN THE ROAD AND IT STARTED COUGHING AND SPUTTERING, SO I TURNED AROUND AND WENT BACK TO THE MECHANIC. HE ADJUSTED THE CHOKE AND I TOOK THE 3020 HOME. WHILE RUNNING A BRUSH HOG THE PROBLEM STARTED UP AGAIN. AT LEAST THIS TIME I HAD A CLUE AS TO WHAT THE PROBLEM MAY BE. I NOTICED THAT THE CHOKE KNOB HAD BEEN PUSHED OUT! AND I HAD NOT DONE IT! SO I PUSHED IT BACK IN AND THE ENGINE RAN SMOOTHLY. THE NEXT TIME I MADE A TURN USING THE BREAKS THE SAME THING HAPPENED AND I PUSHED THE CHOKE KNOB BACK IN. I SPENT THE REST OF THE MOWING SESSION WITH MY TOE ON THE CHOKE KNOB KEEPING IT PUSHED IN. THE ENGINE RAN FINE. IT APPEARS THAT WHEN MORE POWER IS CALLED FOR, THAT THE PRESSURE IN THE CARBURETOR CAUSES THE CHOKE FLAP TO CLOSE AND FLOOD OUT THE ENGINE. NEXT MORNING I MADE SURE THAT THE CHOKE WAS ALL OF THE WAY OPEN AND SET THE SETSCREW ON THE CABLE . I THEN TOOK A PIECE OF LIGHT CHAIN (LIKE SASH CHAIN) AND A SPRING AND HOOKED THEM TOGETHER. THE SPRING WAS COILED THROUGH ONE END OF THE CHAIN. THE OTHER END OF THE CHAIN WAS HOOKED OVER THE SETSCREW FOR THE CHOKE CABLE . THEN THE SPRING WAS STRETCHED FORWARD AND HOOKED TO THE SHROUD OF THE RADIATOR FAN. THIS PREVENTED THE CHOKE FROM COMING ON. THE SPRING IS LIGHT ENOUGH THAT IT DOES NOT PREVENT ME FROM PULLING OUT THE CHOKE WHEN I START THE ENGINE, BUT IT IS HEAVY ENOUGH TO KEEP THE CHOKE OPEN UNDER LOAD. THE TRACTOR RUNS FINE FOR THE FIRST TIME SINCE I HAVE OWNED IT. PLEASE LET ME KNOW IF THIS HELPS YOU. GOOD LUCK! [email protected]
