Clooney I need help please
JDM Guy
08-08-2002 12:22:19
I've replaced the coil, condensor, rotor, point and spark plugs and I still can't get a spark. I've triple checked every thing. I get 8.7 volts at the distributor points when there closed and same when there open. I get 9 volts every were except the plugs. I checked the wire that goes from the top of the coil to the distributor cap and I get nothing. Can you plese help me. I need to mow and I need this thing running.
Clooney
08-08-2002 12:49:13
 Re: Clooney I need help please in reply to JDM Guy, 08-08-2002 12:22:19
JDM Guy, well you have found your problem [sort of]..... "I get 8.7 volts at the distributor points when they're closed and same when they're open".
~Seeing that tells me your points either aren't working or aren't grounding....Try a jumper wire from the points mounting plate to ground, make sure the points are actually closing, make sure the points aren't burnt, blue or oxidized. ~In any case you MUST have close to 0 volts with the points closed if you don't you won't get a spark. So your problem is either in the points, or the points ground or the distributor ground.
