2 cyl diesel headgasket sealant?
Bill R
12-18-2003 20:09:40
Will be putting the head gasket in the "R" while reassembling it after getting a new head for it. What should I use on the headgasket schlack, or do what book says about using motor oil? Also heard about spray copper gasketing or something? Any input is appreciated, thanks
Bill R
A // B // GW // R Diesel
John T
12-19-2003 05:03:57
 Re: 2 cyl diesel headgasket sealant? in reply to Bill R, 12-18-2003 20:09:40
Bill, Im prety much in agreement with the G Power Man. CLEAN SMOOTH AND DRY is the best preparation and I also have had good luck with the high temp copper kote but I avoid it right on/around the cylinder seal areas. Slowwwww progresive even torqueing at 10 lb or so increments in the same and correct pattern is also good (even tho it takes a lot of time) and then a retorque after a good warm up.
Best Wishes and Merry Christmas
John T
Gpower
12-18-2003 21:07:43
Bill, if both mating surfaces, (the head and block face) are good, clean and level, then you could go without any sealant and be ok. I beleive as I recall, the R head torques to around 250 ft lbs, (mine is at 275) but thats pushing it. I do use copper spray sealant on my heads though. It is designed for high heat applications, and is pretty sticky. Allthough when you go to pull the head a second time, the ole gasket is stuck good, and requires a lot more cleaning up than no sealant at all. Its primarily a preferance thing, I do it just to ensure no water leakage. Lilke I say its a 50-50 thing. Good Luck
Gpower
