Powershift not working after sitting
Big Dave
08-06-2002 18:01:39
Just bought a 3020 powershift. it has been sitting since DEC 2001 in a barn. When I cranked it up today it ran fine, tried putting it in gear
and it did not move foward or reverse. I did not leave it in gear very long in either direction.
Is this common for a hyd transmission that has been sitting, does it just need time to build pressure up. I did check all fluids before cranking it up
Brokenwrench
08-06-2002 18:34:11
 Re: powershift not working after sitting in reply to Big Dave, 08-06-2002 18:01:39
If you have no pressure showing on the dash guage, check to see if the transmission disconnect lever is engaged, or if you have pressure on the dash guage is the tow disconnect in the tow position?
