Flywheel Removal
JD60
08-06-2002 15:43:51
John Deere 60 needs its flywheel taken off...I have the clamping bolts backed off....how do I get that lock-nut thing off???
Thanks!!! JD60
Clooney
08-06-2002 17:24:21
 Re: Flywheel Removal in reply to JD60, 08-06-2002 15:43:51
JD60, you will have to unscrew it. Either use a big wrench [a big pipe wrench works good] or bump it around with a screw driver or drift. Once you start moving it the staked part will open up & you should be able to remove it by hand.....
