JD 3010 LP won't start
Mark Whitlow
08-06-2002 01:27:08
It appears the tractor is not producing enough spark to start the engine. This one is setup to start on 12 volts and then a resistor regulates the load down to 6 volts while running. Any help would be appreciated.
LFN
08-06-2002 06:59:13
 Re: JD 3010 LP won't start in reply to Mark Whitlow, 08-06-2002 01:27:08
Spark gap on factory LP tractors must be closer than on gasoline tractors, commonly 0.15, also problems with starting LP engines are most often caused by too much propane, they need to be adjusted so there is no leakage into the carburetor when the engine is not cranking, the vaccuum of the engine needs to draw in the needed fuel, then if every thing else is in good order it will start right up, bad valves are a common problem also.
