4010 won't go
Mike
08-05-2002 20:21:33
my freind has a John Deere 4010 diesel, as he was going down the road , something popped. now it won't move. the motor runs,the gears in the trans. turn, but something seems to be broken between there and the rear end.it is not locked up,they were able to tow it home. What's broke???
DEEREMAN
08-05-2002 20:39:53
 Re: 4010 won't go in reply to Mike , 08-05-2002 20:21:33
I have seen the differential pin break in the rear end and that can let the transmission gears run just fine but not let the tractor move. Also check the key on the rear wheel wedges that they arent broke off. Best way to check the wedges is to start engine and put in gear hold 1 brake then the other. If tractor moves when 1 brake is applied then the opposite wheel wedge may have key sheared off. To check diff pin you need to remove the rockshaft housing. hope this helps
