Looking for disc suggestions
BigMac
08-05-2002 07:23:48
I have a 3010 diesel that I just bought a good used JD145 4-14 plow for it to pull. Can you guys recommend a particular model disc to compliment the plow? Appreciate any suggestions for JD model or other manufacturer. I am looking for something the 3010 can handle easily either 3 point or pull type with lift wheels.
Thanks, BigMac
thurlow
08-05-2002 09:46:37
 Re: Looking for disc suggestions in reply to BigMac, 08-05-2002 07:23:48
A "correct" disc would be a JD "AW" or something similar in about 10 or 10 1/2' width.
Dr. Evil
08-05-2002 08:09:25
Hope You've had some pump work done to that 3010. Our 4010-D used to struggle with 4-14's in Our clay hills! I would buy a 10-12 ft. trailing disc. Anything that big is too big to hang off the 3-point. Anything bigger is too much for the 3010.
BigMac
08-05-2002 08:48:56
 Re: Re: Looking for disc suggestions in reply to Dr. Evil, 08-05-2002 08:09:25
Good Morning Evil One,
By pump, I assume you mean injector pump. Tractor runs good and is ready to plow. The 4-14 will be an easy pull in our sandy loam. My fields have been under till for 170 years. I will be using the plow to turn under green manure(clover, vetch,alfalfa) to build up the soil and will go down no more than 6 inches.
I was thinking no more than a 10' pull disc. My experience has been that the disc always "pulls" more than the plow. Any specific make or model you recommend?
BigMac
kjm
08-05-2002 10:40:08
 Re: Re: Re: Looking for disc suggestions in reply to BigMac, 08-05-2002 08:48:56
BigMac, We pulled a 12foot with an A John Deere you shouldn`t have an trouble,around here a 10 foot and under are gold, I saw a nice IH 12foot wheel disc go for 275.00 Sat. I payed 300.00 for a mounted 8 foot FH IH that needs blades but, I can trailer it with no problems.
