ADDITIONAL on FRONT END WEIGTHS
MIKE HANLEY
12-18-2003 18:39:19
Got thinking about the front end weights mounting and thought I should past this along. When you look at the parts page for the 20/30 series front end weights you will say "HUN?????" It is very confusing as to what is used for which set. (3,4, or 5 piece set and the 6 piece set isn't even covered.) FORGET IT ALL cause most of the bolt parts aren't avaiable any more. After putting on the two side weights with standard bolts and if just one front end weight is put on then use the bolt #12 part # F3042R. For two front end weights, The first stud out of the tractor frame is the same as whats in the axels. Then the long nut #11 part # A5352R. Last I knew that was still availble. Then put on the first weight over the two long nuts. From that point on, it's REDIY-RODS as no more is availible from JD. For the second weight to go on the long nut #11 part A5352R will not fit through the holes. Those nuts and studs are not showen, only listed under AF2855R. They are NO LONGER AVAILIBLE. So for the second weight cut to lenght a piece of rediy-rod and the the long rediy-rod nuts. Line up thje redi-rod nuts so the the flat sides of the nut are up and down and the points of the nuts are top and bottom. Then the third weight goes over the redi-rod with a good snug fit.. If thats it then bolt goes into the redi-rod nut to hold the third weight on. If it is the 5 piece set use the redi-rod and nut again If you are going to put the 6 piece set with the top weight. BEFORE putting on the third front weight, slip two eye bolts over the redi-rod nuts, then put on the third front weigth. After the third front weight is tighten down, the 6th or top weight lays on top of the front and the eye bolts come up through the top weight. All clear as mud,,,RIGHT?????
MIKE HANLEY
12-18-2003 19:02:14
 Re: ADDITIONAL on FRONT END WEIGTHS in reply to MIKE HANLEY, 12-18-2003 18:39:19
All the above stuff is 5/8". Then for the bottom hole take a 3/4" redi-rod and put through all the weights and into the tractor, then a nut, and the cut off the redi-rod even with the nut.
John 51
12-19-2003 05:11:17
 Re: Re: ADDITIONAL on FRONT END WEIGTHS in reply to MIKE HANLEY, 12-18-2003 19:02:14
Hey Mike, I've never seen a '20 or'30 with more than 3 front weights on it. I keep 3 on my 730. How about posting a picture of one with a full set.
MIKE HANLEY
12-19-2003 05:37:14
 Re: Re: Re: ADDITIONAL on FRONT END WEIGTHS in reply to John 51, 12-19-2003 05:11:17
In the book JOHN DEERE 30 PHOTO ARCHIVE on page 82 a 730 gas is pictured with the 5 piece set. On page 84 is pictured a 730 gas with the full 6 piece set. On the 2003 GREEN MAG calender for the month of MAY is pictured my brother-in-laws 720D with the full 6 piece set. Over on the left under tractor photos galleries, go to the bottom of the page and where DEERE is in the box, delete DEERE and type in my name MIKE HANLEY and it should come up with pictures of our tractors. The 730D with the new paint is our main 730 with tractor and has the factory 5 piece set. The 730D with the wide front end (THAT NEEDS A PAINT JOB) that has the 5 piece reproudction set. Or you could do what 12 guys did last night and E-mail me direct. the pictures I send out will download to full screen and if put them in a file then can be Zoomed in on. [email protected]
Bo in Maryland
12-19-2003 11:43:29
 Re: Re: Re: Re: ADDITIONAL on FRONT END WEIGTHS in reply to MIKE HANLEY, 12-19-2003 05:37:14
....real fine photos Mike..... .always good to see two cylinder JDs in action..... a working tractor is a happy tractor...
Good luck to all!
Bo
MIKE HANLEY
12-19-2003 06:06:59
Just tryied the "search for" under the photo galleries and it came up with 10 pictures of out tractors. Only DEERE isn't in the box. The box is blank. Type in my name and hit GO.
Joe P.
12-19-2003 04:41:24
"Sometimes in the evenings after supper, Mike talks to himself. The cows understand him but can't talk back." GL
MIKE HANLEY
12-19-2003 05:46:46
 Re: Re: Re: ADDITIONAL on FRONT END WEIGTHS in reply to Joe P., 12-19-2003 04:41:24
Some days when I talk to myself, it's the only intellagent conversation I have. But what is really strange is when my wife of 39 years and I have a talk and then three days later pick up on the talk without skipping a beat like the whole talk just took place. Good or Bad????? But I was at my best on the stand in court when the defence lawyer would try to run me in circles, and I would turn rigth around and turn the lawyer in circles. AHH I miss those days. But the retirement check is nice.
