420C left steering clutch housing
tubba_JD420C_ny
08-04-2002 10:31:49
The left steering clutch housing on my early (S/N 86890) 420C has a crack about midway between the two large "ears" on the front of the housing & extending inboard abt. 2 in. from the final drive mounting flange. I got another housing, but this turned out to be the later "four-bolt" design with one long ear with four holes in it, which looks like a heavier design. I think that maybe these two-bolt housings have been cracking so JD beefed them up in the later 420C's. It looks like it would bolt up, but to be safe, I got another housing of the same "two-bolt" style. This one turned out to have a crack just the same as the other one. I got the crack welded, but now my question is Were these housings prone to cracking? Has anyone else out there noted a crack in the left steering clutch housing on their early (S/N < 100,000, all green)420C or 40C? If these housings were prone to cracking, then I will install the heavier "4-bolt" one. Thanks for wading thru this long winded message and for any help.
CPETER
08-04-2002 10:56:09
 Re: 420C left steering clutch housing in reply to tubba_JD420C_ny, 08-04-2002 10:31:49
Yes they were prone to cracking. The good news is that they are all interchangeable, if my 30 year ago memory is right. I am running the later 420 housings on my 40C. Also, the final drive housings were very prone to cracking and there are at least 3 o4 different versions of these. I have two different 420 housings on my 40 and I think that in my pile of spares there are two more different ones. Again, these will bolt on.
tubba_JD420C_ny
08-04-2002 15:19:47
 Re: Re: 420C left steering clutch housing in reply to CPETER, 08-04-2002 10:56:09
I thought so. Thanks for getting back to me. Since I do have the one heavier clutch housing, i will use it in place of the original design. I have heard about the final drive housings cracking, too, but so far, (knock on wood) mine seem OK. Thanks for the tips
