H Block
EJ
08-03-2002 21:17:59
I find that the block on my H JD has a small crack between the water port and the port where the push rods go through. The crack is into the port about an inch, so impossible to weld. Any suggestions, or where would I start looking for a block, std pistons? Thanks
HMan
08-04-2002 09:06:43
 Re: H Block in reply to EJ, 08-03-2002 21:17:59
EJ, Call C.B. Lindstrom @816-232-5868. He is the H parts man. He might have a standard bore you can use, if not he has a man that can sleeve and bore one for you. HMan
