Aftermrkt wfe for 2030
Dave_Id
08-02-2002 09:21:33
Does anyone know of a mfg'r of a wfe like a Schartz or similar to fit a 2030. The steel on these spindles just can't take a loader, and these bales are only 550#'s.....snapping them off left and right
John
08-02-2002 12:35:21
 Re: Aftermrkt wfe for 2030 in reply to Dave_Id, 08-02-2002 09:21:33
Ive got three Deeres with loaders and never had a problem with spindles. Check a parts book and I`m kinda sure you will find two different front axle/spindles for your 2030. Two different styles also. Straight/adjustable and fixed/adjustable. Regular duty and heavy duty. My bet is you have a regular duty axle. Industrial axles mite fit and work but if you have that kind of work to accomplish buy an industrial machine.
Dave_Id
08-02-2002 14:27:36
 Re: Re: Aftermrkt wfe for 2030 in reply to John, 08-02-2002 12:35:21
I've got the heavy duty, but maybe you are just lucky with your spindles, I've broken four, and like I said before, these bales are only 550#'s, no way should they be breaking at all. And to top it all off JD has quit mfg'ing them. At $168 a pop, they should be a money maker for JD. I see that Value-built carries them, maybe they would have better quality steel in theirs
gy3020
08-02-2002 15:52:22
 Re: Re: Re: Aftermrkt wfe for 2030 in reply to Dave_Id, 08-02-2002 14:27:36
My question would be, how fast are you driving and what type of terrain are you going over? That shouldn't be a problem for the front end with less than 600 pound bales!
SmallOps
08-03-2002 03:00:04
 Re: Re: Re: Re: Aftermrkt wfe for 2030 in reply to gy3020, 08-02-2002 15:52:22
I have to agree with gy3020. I can't help trace down your difficulity, but I can say that the engineered WFE strength of the JD 1020 series tractors, which includes your JD 2030, would easily handle the loads your are placing on your machine.
