JD 450 Crawler Tractor
bgreen
08-01-2002 17:52:59
I recently acquired a 1970 or so John Deere 450 crawler tractor. It has the 4 speed gear box and the hydraulic HLR speed range/reverser lever. The tractor will only move in speed range 4. In speed ranges 1-3 there is some noise from the hydraulic clutches, but no movement. Also, the speed range shifter can only be shifted when the engine is off. When the engine is running the gears clash and cannot be changed. I have the JD shop manual, but I can't figure out why it only moves in speed range 4. Any ideas as to what to look for would be greatly appreciated.
JD450_Rick
11-20-2006 17:02:31
 Re: JD 450 Crawler Tractor in reply to bgreen, 08-01-2002 17:52:59
I have had the same problem...would be nice to hear a solution...
nadonm
01-10-2006 16:00:33
test
